TwinTurbo.NET: Nissan 300ZX forum - How does the launch control cut fuel and spark? (n/m)
ZEVAN (Ca)
on October 19, 2009 at 1:56 PM
You have to find a medium between bogging and spinning
posted by TTFairladyZ
on October 19, 2009 at 12:21 PM
Tips for the dragstrip with slicks?
Ice95z
11:18:33 10/19/09
TTFairladyZ
12:21:21 10/19/09
How does the launch control cut fuel and spark? (n/m) -
ZEVAN (Ca)
13:56:49 10/19/09
It should only be ignition not fuel; cutting fuel would
Machtavian
14:06:53 10/19/09
I think the link he posted says fuel and spark. Anyways, I
ZEVAN (Ca)
14:14:38 10/19/09
It's fuel and spark simultaneously
TTFairladyZ
15:40:53 10/19/09
TT diff should be fine, axle might break if you wheel hop (n/m)
ztunerz
12:25:24 10/19/09
Profile says NA rear end. (n/m)
Dream Z
12:33:45 10/19/09
well then - get ready for a wanted add for a na diff :) (n/m)
ztunerz
21:42:58 10/19/09
Slicks + NA rear + 1-pc AL Driveshafe = bad times?
08:37:07 10/20/09
no (n/m)
JustinSCZ32
12:17:08 10/20/09
I mean bad times as in broken parts. I know if nothing
14:03:08 10/20/09
From my experience, I would launch around
Machtavian
13:30:06 10/19/09
Re: From my experience, I would launch around
Ice95z
13:39:49 10/19/09
I was a ten psi on that run.
Machtavian
13:47:41 10/19/09
skinnies will not prevent that.... (n/m)
zxtuner161
16:30:10 10/19/09
They help steer it straight... (n/m)
Machtavian
17:33:40 10/19/09
no they don't... u can get just out of control with
zxtuner161
17:38:12 10/19/09
Those 26x11.50 et streets are bias ply (n/m)
nissanguyz32
18:48:30 10/19/09
He's right, they are bias ply. (n/m)
MeatMan - 604Z.ca -
20:52:00 10/19/09
You obviously have no idea that those are bias ply
Machtavian
19:21:13 10/19/09
not all skinnies are bias ply... mine are radials
zxtuner161
21:18:40 10/19/09
Re: not all skinnies are bias ply... mine are radials
Ice95z
08:15:19 10/20/09
bias ply you get a much softer sidewall, a "wrinkle wall"
zxtuner161
08:29:37 10/20/09
Re: bias ply you get a much softer sidewall, a "wrinkle wall"
Ice95z
08:48:22 10/20/09
Is that sac raceway? I was hoping to see you there last
ZEVAN (Ca)
13:48:29 10/19/09
I was in Fallon Nevada at top gun raceway on Saturday
Machtavian
14:00:56 10/19/09
Are you going anytime soon? I'd love to see your z run. I
ZEVAN (Ca)
14:08:49 10/19/09
Not sure, but ill let you know if/ when i go out. (n/m)
Machtavian
14:11:13 10/19/09
Re: Tips for the dragstrip with slicks?
cinpatico
16:38:05 10/19/09
I have a 1 piece ds. My boost controller is a old
Ice95z
17:35:34 10/19/09
How do you boost 8psi? Aren't your wastegates set higher? (n/m)
08:44:56 10/20/09
Launch at 7000rpm and hold on... I had gotten 1.63 60ft (n/m)
dream Z (MD)
09:44:47 10/20/09
